davidr1
Jul 30, 2021Luminary
ssh: permission denied (publickey)
Hi, I tried to ssh into my 314, [email protected] I got a message saying, from memory, did I want to import the certificate (yes,no) Replied yes But now what happens is: ssh [email protected] roo...
- Aug 01, 2021
One thing you could try is deleting the known_hosts file in the pc.
This is in c:\users\user-name\.ssh (which is a hidden folder). You'll get the prompt on whether you want to trust the NAS again after you do this.
Jul 31, 2021Guru - Experienced User
Check that "password authentication" is checked in the SSH settings in system->settings->services.
davidr1 wrote:
Hi,
Was this the first time you used ssh to connect to the NAS on this PC? There will be a prompt asking asking if you trust the NAS, and showing you some fingerprint information. Importing the certificate allows you to avoid that prompt in the future.
- SandsharkJul 31, 2021Sensei
When you enabled SSH, did yoiu check the "Enable password authentication" box?
- davidr1Jul 31, 2021Luminary
Hi StephenB,
Yes - it is and was.
- StephenBAug 01, 2021Guru - Experienced User
- davidr1Aug 01, 2021Luminary
That worked - thank you very much.
