Retired_Member
May 09, 2017SSL Cert not secure
The SSL cert (to manage NAS) was good until I changed the NAS from "local users" to "Active Directory". *The SSL Key Host is the IP address of the NAS, and the cert is still in the Trustede Root Cer...
May 09, 2017Guru - Experienced User
I suspect the IP address of the NAS changed after you generated the self-signed cert.
Retired_Member
May 09, 2017nope, I access the NAS with the same static IP.
I have the NIC's bonded, with 1 IP...and I just checked and its the same IP as the SSL Key Host
