Polaris1980
Oct 03, 2015Aspirant
Standard settings shares does not give full access
Hi I have a Readynas Ultra 6 with RAIDiator 4.2.22. Recently I had to do a factory reset. Now I am reconfiguring the NAS. I got stuck creating the shares. I read several topics on the matter; bu...
Polaris1980
Oct 04, 2015Aspirant
Hi
Thanks for your reply
Unfortunatly that did not do the trick.
I see the share in windows, I can open it; but the folder it should download is not accessable.
The funny thing is; after that did not work; I also checked" Set ownership and permission for existing files and folders to the above settings. This option is ueful in cases where you are changing security level and you need to workaround files access problems".
This then works for all excisting folders. But after I make new ones; I need to do that again.That is not a desired option.
Did you ever came across this issue? Any thoughts on what I am doing wrong? Any help is appreciated.
Polaris1980
Or is my NAS software broken.:smileyfrustrated:
