Polaris1980
Oct 03, 2015Aspirant
Standard settings shares does not give full access
Hi I have a Readynas Ultra 6 with RAIDiator 4.2.22. Recently I had to do a factory reset. Now I am reconfiguring the NAS. I got stuck creating the shares. I read several topics on the matter; bu...
Polaris1980
Oct 04, 2015Aspirant
Hi
Thanks for your reply
Unfortunatly that did not do the trick.
I see the share in windows, I can open it; but the folder it should download is not accessable.
The funny thing is; after that did not work; I also checked" Set ownership and permission for existing files and folders to the above settings. This option is ueful in cases where you are changing security level and you need to workaround files access problems".
This then works for all excisting folders. But after I make new ones; I need to do that again.That is not a desired option.
Did you ever came across this issue? Any thoughts on what I am doing wrong? Any help is appreciated.
Oct 04, 2015Guru - Experienced User
If resetting the ownership worked, then that means then the issue is definitely linked to ownership.
Did you try setting "Do not allow ACL changes to be more restrictive than this." on the advanced permissions page?
Also, is this happening with one of the NAS default shares, or is this a share you created?
There is a simple work-around - that is to create a credential for the NAS in the windows credential manager. For instance, use admin for the log-on (and the NAS admin password for the password).
- Polaris1980Oct 11, 2015Aspirant
Hi
Due to busy times on work I did not have a chance to try the solutions posted. My apologies
The issue is for both the pre instaleld shares as the newly created. As said I can enter the share but the folders created within the shares are not accessable.
The "Do not allow ACL changes to be more restrictive than this" did not fixed the issue
Strangely enough; the credential manager does not solve it. Probably because the share is (ans was) accessable; but not the creates sub folder.
The folders are created by SABNZBD. Could that have something to do with it?
- StephenBOct 11, 2015Guru - Experienced User
Did you try resetting the owner/group and permissions using the advanced options tab for the share?
Select the checkbox, and appl (bottom right). The checkbox will clear immediately, and after a while there will be a popup telling you that the resetting is complete.
- Polaris1980Oct 12, 2015Aspirant
Hi
Again, thank you for helping me. Much Appreciated.
I already did that step. if you meant: " Set ownership and permission for existing files and folders to the above settings" in the advanced setting.
I did it again to be sure, and the sysyem gave me a notification that reetting is complete.
As said this did help for the excisting folders in that share. However, when SABNZBD creates new folders in that share they are blocked again.
I also can create folders from windows in that share. Could it be SABNZB related?
Kind regards
