gbeddow
Apr 25, 2019Luminary
STILL STUCK: failed upgrade from 6.9.5 to 6.10.0
I posted this yesterday and got no reply; can someone from Netgear please reply?
I upgraded an RN202 from 6.9.5 to 6.10.0 and many things are broken now. So many, in fact, I won't list them all...
- Apr 27, 2019
Sandshark, I was running PHP 7.2.13. Unfortunately, rolling back to 5.6.40
didn't solve it, but I noticed an error restarting apache that I fixed with:# a2enmod slotmem_shm
After that, and restarting the RN202, most of the installed apps came back - except for LogAnalyzer, which is a shame because it's quite useful.Does OS 6.10.0 no longer support LogAnalyzer, or is that issue specific to my system?
Sandshark
Apr 26, 2019Sensei
What version of PHP are you using? OS6.10.0 "broke" PHP 7 supplied by ReadyNAS Xtras, and thus any apps relying on it.
- gbeddowApr 27, 2019Luminary
After that, and restarting the RN202, most of the installed apps came back - except for LogAnalyzer, which is a shame because it's quite useful.Does OS 6.10.0 no longer support LogAnalyzer, or is that issue specific to my system? - SirTobyMay 19, 2019Aspirant
I logged on to the console and killed the apache update process, then did:
apt-get update
apt-get upgrade -y
reboot
After this, Apache would start again and all seemed fine. A bit slow but working.
Hope this helps
