Ger1234
Jul 30, 2017Aspirant
Storage NAS gone?
Hello, I hope someone can help me with my problem. Somehow I lost 92GB of storage in 2 days without copying any files to my NAS (ReadyNAS Duo v2) (I have upgraded the NAS with the latest firmwa...
- Aug 13, 2017
I suggest you use "du -h --max-depth=1 /c/" to investigate where 92GB has gone... should be easy-ish to find I would think.
Ger1234
Update latest Firmware:
Tue Jul 18 17:15:58 CEST 2017
Your ReadyNAS device has been updated with a new firmware image. (RAIDiator-arm-5.3.13)
No errors found after Volume scan (Reboot)
***** File system check forced at Sun Jul 30 21:05:14 CEST 2017 *****
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: 104603/30285824 files (33.7% non-contiguous), 484570005/484573184 blocks
Jul 31, 2017Guru - Experienced User
So you know what forced the file system check on 7/30?
- Ger1234Jul 31, 2017AspirantYes, I did.
Because my free storage was "drained". I hoped it was a temporary file and maybe a reboot could solve the problem. When I rebooted the NAS I received a pop-up to do a volume scan.- StephenBJul 31, 2017Guru - Experienced User
I think the next step would have to be some form of data recovery.
https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service is one option, some folks have also reported good results with ReclaiMe.
