Ger1234
Jul 30, 2017Aspirant
Storage NAS gone?
Hello, I hope someone can help me with my problem. Somehow I lost 92GB of storage in 2 days without copying any files to my NAS (ReadyNAS Duo v2) (I have upgraded the NAS with the latest firmwa...
- Aug 13, 2017
I suggest you use "du -h --max-depth=1 /c/" to investigate where 92GB has gone... should be easy-ish to find I would think.
aks
Jul 31, 2017Virtuoso
Ger1234 wrote:Is the a way to check the disc usage on the NAS? In order to find out where my storage went?
If you log in to the command line via SSH you could start with using "du" to observe used space and look for large allocations. 92G should be easy to find!
- Ger1234Aug 13, 2017Aspirant
Sorry for the late reply, I was on Holiday
When I check the free space with SSH it also states all the storage is used by "c" (100% used).
Is there a command to get more details?
- aksAug 13, 2017Virtuoso
Thanks, I found it.
Looks like me (or my wife) made a copy of the entire photo directory to the photo directory.
With this command I was able to detect the large photos copy
du --max-depth=1 /c/photos
Thanks for your help.
