Ger1234
Jul 30, 2017Aspirant
Storage NAS gone?
Hello, I hope someone can help me with my problem. Somehow I lost 92GB of storage in 2 days without copying any files to my NAS (ReadyNAS Duo v2) (I have upgraded the NAS with the latest firmwa...
- Aug 13, 2017
I suggest you use "du -h --max-depth=1 /c/" to investigate where 92GB has gone... should be easy-ish to find I would think.
Ger1234
Aug 13, 2017Aspirant
Sorry for the late reply, I was on Holiday
When I check the free space with SSH it also states all the storage is used by "c" (100% used).
Is there a command to get more details?
aks
Aug 13, 2017Virtuoso
