Philein
Aug 06, 2020Aspirant
Storm Control kills my NAS connectivity
Hi everyone I'm trying to improve my SO intranet. I noticed the storm control on my 3 Netgear Switches was off, so i turned it on. Everything's fine except it kills my local NAS connectivity. It b...
Aug 06, 2020Guru - Experienced User
Philein wrote:
If i understand correctly this should work only on storm traffic and not on regular traffic (id. for example the LAN traffic to the NAS)
Well, it seems to be doing more than that.
Do you have any evidence that there are traffic storms on your network? e.g., network outages or dropped packets in the switch with storm control turned off?
Have you compared the traffic loss statistics in the NAS with the feature enabled/disabled in the switches?
Personally I just leave it off. But you might try just turning off the unknown unicast storm control and see if that resolves the problem.
