ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
Sandshark
Jan 14, 2017Sensei
Others have reported the NAS incorrectly reporting a problem with a share when it's the OS partition that's almost full, and that sounds like your problem. There are several things that can cause it. But you need to check before it gets completely full and you are unable to access Frontview.
Currently, the only way to check/fix a filling OS partition is via SSH (and tech support mode, I thnk) and some knowlege of Unix or specific directions. I have put in a suggestion that better tools be provided for preventing and fixing this issue. There are a number of existing message chains on this subject.
