ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
Sandshark
Jan 14, 2017Sensei
Others have reported the NAS incorrectly reporting a problem with a share when it's the OS partition that's almost full, and that sounds like your problem. There are several things that can cause it. But you need to check before it gets completely full and you are unable to access Frontview.
Currently, the only way to check/fix a filling OS partition is via SSH (and tech support mode, I thnk) and some knowlege of Unix or specific directions. I have put in a suggestion that better tools be provided for preventing and fixing this issue. There are a number of existing message chains on this subject.
Paul608085
Jan 15, 2017Tutor
I am getting this warning regularly for the past couple of days on my RN214: "System volume root's usage is 95%. This condition should not occur in normal conditions. Contact technical support." Is this the same thing? ( I am also getting the less than 5% free warning).
I was getting it on OS v6.6.0 and after upgrading to v6.6.1
I have linux-dash installed and I see this:
Disk Usage
Filesystem Size Used Avail Use% Mounted
| /dev/md0 | 3.7G | 3.5G | 0 | 100% | / |
| /dev/md127 | 11T | 2.6T | 8.4T | 24% | /data |
| /dev/md127 | 11T | 2.6T | 8.4T | 24% | /home |
| /dev/md127 | 11T | 2.6T | 8.4T | 24% | /apps |
| tmpfs | 1009M | 0 | 1009M | 0% | /dev/shm |
I can see that it is /dev/md0 that is reporting to be full, what can I do about it? I am OK with SSHing and Linux command line, but I don't know what commands I need to use.
Can anyone help please?
Paul
- Retired_MemberJan 15, 2017
You can use du to locate where the space is used. This situation (full root) can occur for different reasons, most common ones are applications installed from backend (like mysql or crashplan), log files that aren't rotated (added by apps), etc.
1. cd into the path you want to analyze first
2. du tells you where the space is used
3. cd into biggest folder
4. du
5. Repeat until you find the folder containing the files, then use ls
# cd / # du -d1 -hx . -> var is the biggest # cd var # du -d1 -hx . -> log is the biggest # cd log # du -d1 -hx . -> current folder only is big # ls -alh
The step by step approach is interesting to analyze the filesystem usage. But there are shortcuts available, like this one:
du -hx / | sort -hr | head -n 10
If the first line doesn't show 4GB, then there might some data in a folder that is not readible using du (for example, /data, but not on the data volume, on the OS volume ; data that was created under the mountpoint path before the other volume was mounted).
- Paul608085Jan 16, 2017Tutor
Thanks for reply.
I found that Logitech Media Server was one of the largest folders at around 450MB, ClamAV was only slightly smaller (IIRC). I have been using the Super-Poussin version of LMS since the problems that happened when the OS was upgraded to 6.6.0 and I saw on another thread that this could have been causing a problem since it writes a lot of data to root (?). I tried uninstalling it and manually removing the associated folders that I could find, but only managed to get /dev/md0 down to 94% used. Uninstalling all of my remaining apps had no effect on this, so I decided that the only way I was going to be able to completely clear it out was a full factory reset and rebuild, (luckily I had updated my backup the day before!). The Volume is still resyncing, but I have re-installed LMS, (NAStools version from the repository this time), DVBLink, linux-dash and Transmission. I will activate the Anti-Virus after the volumes have re-synced as it seems to slow it down a lot.
Linux-dash is now showing:
Disk UsageFilesystem Size Used Avail Use% Mounted/dev/md0 3.7G 484M 3.0G 14% / I'll keep an eye on it to see if if uses significantly more over time.
Thanks again,
Paul
