ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
rick_heinig
Jan 24, 2017Aspirant
Hi, having yellow codes come up with low media capacity. Todays codes pasted below. Helpful information is that system is updated to 6.6.1 and perform USB backups to 2T Toshiba drive. You can see that antivirus has been updated recently. I'm having difficulty getting scans from our network printer/copier/scanner. Is this related to the low media capacity errors? How can I fix it?
NielsenNAS
- StephenBJan 24, 2017Guru - Experienced User
Is the volume actually over 90% full?
If not: There's some indication from other posters that suggests the new AV might be misbehaving. You might try turning it off for a day and see if the system behaves better.
- rick_heinigJan 24, 2017Aspirant
Hi Steve, just under 2.38 TB available. I can try shutting the system down overnight tonight. However, I have unplugged it and replugged it in this morning...still got the low media capacity codes.
- ikonukJan 24, 2017Guide
StephenB wrote:Is the volume actually over 90% full?
StephenB:
I have received two definition updates (one yesterday and one this morning), so far so good. NETGEAR may have resolved the issue. Let us wait few days and see.
I. Konuk
Hi Konuk, is this message in my logs pertaining to the system updating my netgear? "System: ReadyNASOS background service started"
