ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
ikonuk
Feb 01, 2017Guide
FramerV wrote:Hi ikonuk
Based on the description of the issue that you have provided, I may need to check this with others who can probably assist you and get back to you as soon as possible.
Thanks for your cooperation!
FramerV:
I have not heard from NETGEAR. But I have not had any new warnings either. Can we assume that this issue is now taken care of? Or should we wait for further notice or action?
Regards;
I. Konuk
Feb 01, 2017Guru - Experienced User
- rick_heinigFeb 01, 2017Aspirant
Good news, we'll be looking for the next update.
- ikonukFeb 22, 2017Guide
Unfortunately, I got another one of these warnings about 5% disk space available (although 80% is free) right after this monring's Virus Definition update. I am inserting a segment of the log.
I hope Netgear has a solution soon!
I. Konuk
- StephenBFeb 22, 2017Guru - Experienced User
If you are running 6.6.1, you should either disable the AV service or you should install 6.7.0 beta.
StephenB:
Thank you very much for your suggestion. I have done so. But at first attempt the sytem gave me an error and ignored the request. I rebooted the system and tried again. Now AV is off and my system is more responsive now.
I hope Netgear completes the testing of 6.7 soon.
Regards;
I. Konuk
