ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
Roel1
Mar 04, 2017Apprentice
I am having the same or similar problem:
[17/03/03 09:02:09 WET] warning:volume:LOGMSG_VOLUME_USAGE_NOTICE Less than 30% of volume data's capacity is free. NETGEAR recommends that you add capacity to maintain current performance levels. Continuous protection snapshots will be deleted when volume free space is less than 5%.
[17/03/03 09:02:40 WET] notice:system:LOGMSG_ANTIVIRUS_DEF_UPDATE Antivirus scanner definition file was updated to 57.23158.
[17/03/03 09:02:29 WET] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[17/03/03 19:57:53 WET] warning:volume:LOGMSG_VOLUME_USAGE_CRITICAL Less than 5% of volume media's capacity is free. Performance on volume media is degraded. To improve performance, you must add capacity.
My ReadyNAS is also a whole lot slower. I will disable the AV to see if it makes a difference.
FramerV
Mar 05, 2017NETGEAR Employee Retired
Hi Roel1,
You could also consider updating to the BETA firmware.
ReadyNASOS 6.7.0-T180 (Beta 3)
