ikonuk
Jan 14, 2017Guide
Strange Warning: Less than 5% of volume media's capacity is free.
I got a strange Warning ofrom my RN102 after upgrading to ReadyNAS 6.6.1. "Volume: Less than 5% of volume media's capacity is free." When I browse the sytem via the Web interface I see that I...
- Feb 01, 2017
On another thread, Netgear said they'd be starting a 6.7.0 beta very soon to roll out AV fixes.
FramerV
Mar 05, 2017NETGEAR Employee Retired
Hi Roel1,
You could also consider updating to the BETA firmware.
ReadyNASOS 6.7.0-T180 (Beta 3)
FramerV
Mar 10, 2017NETGEAR Employee Retired
Hi Roel1,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Roel1Mar 11, 2017Apprentice
Hi Framer V
I disabled AV on the ReadyNAS, which helped a bit, but haven't tried the beta yet. I'll see if that helps.
Regards
- FramerVMar 11, 2017NETGEAR Employee Retired
Hi Roel1,
Thanks for the feedback.
Let us know if you have any issues with the BETA.
- Roel1Mar 18, 2017Apprentice
Hi FramerV
I've checked the logs now that a week has gone by and I've not noticed any problems with the beta. And I am no longer getting the Less than 20% or 5% warnings.
Regards
