MK9991
Feb 25, 2013Aspirant
Streaming problems
Made a post about this a while ago but it was a bit of a mess as it was written while also investigating the issue. The problem I have is basically an inconsistent very low performance by the ReadyNAS...
Feb 25, 2013Guru - Experienced User
What firmware are you running? Also, what add-ons (if any) do you have installed?
