MK9991
Feb 25, 2013Aspirant
Streaming problems
Made a post about this a while ago but it was a bit of a mess as it was written while also investigating the issue. The problem I have is basically an inconsistent very low performance by the ReadyNAS...
Feb 28, 2013Guru - Experienced User
It shouldn't be slowing down then.
Have you checked the disk SMART stats? Also, some of the newer seagates have issues, so you might want to post the model number (and the firmware version the drive is running).
