MK9991
Feb 25, 2013Aspirant
Streaming problems
Made a post about this a while ago but it was a bit of a mess as it was written while also investigating the issue. The problem I have is basically an inconsistent very low performance by the ReadyNAS...
MK9991
Mar 01, 2013Aspirant
I did check the firmware as I know of "clicking" issues with the seagate drives, it's on the most up to date possible already.
Info on the disk:
SMART Information for Disk 1
Model:
ST3000DM001-9YN166 2794 GB
Serial Number:
Z1F1T6J9
Firmware Version:
CC4B
SMART Attribute
Spin Up Time:
0
Start Stop Count:
50
Reallocated Sector Count:
0
Power On Hours:
1400
Spin Retry Count:
0
Power Cycle Count:
50
Runtime Bad Block:
0
End-to-End Error:
0
Reported Uncorrect:
0
Command Timeout:
0
High Fly Writes:
1
Airflow Temperature Cel:
33
G-Sense Error Rate:
0
Power-Off Retract Count:
49
Load Cycle Count:
4227
Temperature Celsius:
33
Current Pending Sector:
0
Offline Uncorrectable:
0
Load cycle count seems high? but I've no idea if it's just high, or that's high even for a load cycle count.
Info on the disk:
Model:
Serial Number:
Z1F1T6J9
Firmware Version:
CC4B
SMART Attribute
Spin Up Time:
0
Start Stop Count:
50
0
Power On Hours:
1400
Spin Retry Count:
0
Power Cycle Count:
50
Runtime Bad Block:
0
End-to-End Error:
0
Reported Uncorrect:
0
Command Timeout:
0
High Fly Writes:
1
33
G-Sense Error Rate:
0
49
Load Cycle Count:
4227
33
0
0
