pleasantone
Dec 14, 2015Aspirant
Stuck at "Checking root FS..."
Pro Pioneer, extra RAM, quad core CPU, been running 6.4.1, and the device was recently factory defaulted (after installing 6.4.1rc2) and data reloaded into it. The past two weeks, sometime betwe...
jetheroheller
Mar 20, 2016Tutor
Any resolution to this? I may be having a similar issue.
BrianL2
Mar 20, 2016NETGEAR Employee Retired
Hi jetheroheller,
Which system and Firmware are you using? Have you receive an email notification from NETGEAR about the health or status of the drives in your system?
Looking forward hearing back from you.
Kind regards,
BrianL
NETGEAR Community Team
- jetherohellerMar 20, 2016Tutor
BrianL2 I raised a separate thread with my own details, which you have found. Thank you for your help. I was just wondering if this story had a happy ending....
I'll follow up with you and/or mdgm on that other thread.
