twc
Jul 06, 2016Aspirant
Stuck on "display is page_address+c" after firmware update
Hello, My ReadyNAS 104 prompted me to update the firmware last night. So I agreed, and it has been stuck on the reboot stage for about 14 hours so far. The message on the display is "page_add...
- Jul 20, 2016
twc wrote:
And no more firmware updates. Ever.
Your 'display is page_address' issue could potentially be related to the mv_xor message that other individuals were getting on their RN104s. We released a 6.5.2 beta yesterday which should address that issue (although too late since you were recommended to restore to factory default). I would recommend always staying up to date on firmware though -- we fix a lot of security stuff in each release and address potential issues you could run into.
BrianL2
Jul 06, 2016NETGEAR Employee Retired
Hi twc,
I apologize for the inconvenience this has caused you. I don't see any problem rebooting your unit unless there is a problem with your hard drives. Anyway, I will give this a go and hopefully the unit will boot up just fine.
Kind regards,
BrianL
NETGEAR Community Team
- twcJul 06, 2016Aspirant
Thank you Brian.
I did that within a few minutes of your reply - and it now appears to be stuck on "Rebooting 77%" (an hour or two I guess). The progress indicator is still flashing, implying that it's trying to get to 78%.
- twcJul 07, 2016Aspirant
Still 77% :(
- BrianL2Jul 07, 2016NETGEAR Employee Retired
Hi twc,
I apologize. The system should at least have the 6.2.5 loaded before updating to 6.5.0 or 6.5.1. Anyways, can you check if you can boot up the system in Volume read only mode? You can check the steps here.
Kind regards,
BrianL
