twc
Jul 06, 2016Aspirant
Stuck on "display is page_address+c" after firmware update
Hello, My ReadyNAS 104 prompted me to update the firmware last night. So I agreed, and it has been stuck on the reboot stage for about 14 hours so far. The message on the display is "page_add...
- Jul 20, 2016
twc wrote:
And no more firmware updates. Ever.
Your 'display is page_address' issue could potentially be related to the mv_xor message that other individuals were getting on their RN104s. We released a 6.5.2 beta yesterday which should address that issue (although too late since you were recommended to restore to factory default). I would recommend always staying up to date on firmware though -- we fix a lot of security stuff in each release and address potential issues you could run into.
twc
Jul 08, 2016Aspirant
Thank you for the tip.
Any idea what I should do next though, when the sync finishes?
Do we think it should reboot fine into normal mode? Or should I be doing something else first, such as rolling back to an earlier firmware to avoid it hanging at 77% again?
Jul 08, 2016Guru - Experienced User
If Netgear offers suggestions, then of course go with them.
Otherwise, I'd just restart and see what happens. It might be that the combination of resync and something else (computing quotas or some similar processing required by the update) is what caused the problem.
I wouldn't roll back software..
