Soccerman18
Sep 01, 2015Aspirant
Stuck on IP 192.168.168.168
I have a ReadyNAS Ultra 4 Plus, after a recent power outage every time the NAS powers up it has the IP of 192.168.168.168. Every other device connected to the router is working correctly. I tried p...
Sep 02, 2015Guru - Experienced User
192.168.168.168 is the failover address when DHCP fails. You might check the router config and make sure that it has enough addresses to hand out.
Are you connecting both NICs on the ultra? If so, try removing one of the cables. If not try moving the cable to the other port.
