Blues11
Nov 23, 2018Luminary
Sudden slow speeds on NAS
In the past few days I've noticed a dramatic slowdown in speeds when copying files to and from the 516. File transfers that used to take a minute or less now take 10 minutes or more. I've rebooted th...
- Dec 04, 2018
Yep. It was that Netgear switch. I replaced it with a new 16 port switch and the ridiculously slow network speeds disappeared. It confused me that other network traffic seemed to work properly, but thsi solved the problem.
Thank you for the help.
Blues11
Nov 25, 2018Luminary
OK. I think the problem is with the switch, even though the other computers on the network seemed to be unaffected by it. I just found another 1Gbps switch with 8 ports and substituted that for the 16 port one. The result was basically the way it was before this slowdown happened. I'll run it this way for 24 hours but this seems to have solved the problem.
If I'm still having issues I'll post them, but if the other switch keeps the network at the speeds it has now, I'll post that to confirm and then I'll close this as "resolved."
Thank you.
Blues11
Dec 04, 2018Luminary
