mardolas
Jan 08, 2015Aspirant
Suggestion NAS for Plex
Hi All, i should buy a NAS and i need a suggestion. Features needed: - Budget: max 400€/450$ HDD includes - Slot: at least 2 bay - Storage: at least 4 tb - SW: Plex + Bittorrent - Chromecast...
Jan 08, 2015Guru - Experienced User
Good. Over the internet, transcoding can be needed to reduce the bandwidth needed. In the home you can usually find apps that can play your current content. Android built-in players will play most stuff. IOS is more restrictive. I find AVPlayerHD works well on the ipad for my video content (using FTP as the protocol for access).
mardolas wrote:
StephenB wrote: Mardolas, you aren't mentioning any other streaming. Is playback on mobile devices another requirement? If so, is this only in the home or over the internet?
Actually only in the home.
Hopefully we've given you enough info to get started, post back if you have any followup questions.
