Elanthius
Feb 16, 2012Aspirant
Swapped drives now Not-Redundant
My ReadyNAS NV+ v2 was full of 1TB disks and I've been replacing them over time with 3TB disks. The last swap out seemed to work fine except now the web interface shows X-RAID2 (Not-Redundant) which m...
Elanthius
Thanks for your help. The barrier to entry for Netgear tech support is too high so I'll just try swapping out a 1TB disk next time I get a 3TB in and see where that leaves me. Maybe it'll resync itself back into correctly working.
