Elanthius
Feb 16, 2012Aspirant
Swapped drives now Not-Redundant
My ReadyNAS NV+ v2 was full of 1TB disks and I've been replacing them over time with 3TB disks. The last swap out seemed to work fine except now the web interface shows X-RAID2 (Not-Redundant) which m...
mdgm-ntgr
Feb 16, 2012NETGEAR Employee Retired
Removing the 3TB disk last added while the NAS is on, waiting 30 seconds or so, checking to see that you can still access your data and if you can still access your data then readding the disk will likely resolve the problem. A resync will occur and your volume should then be redundant again.
