Elanthius
Feb 16, 2012Aspirant
Swapped drives now Not-Redundant
My ReadyNAS NV+ v2 was full of 1TB disks and I've been replacing them over time with 3TB disks. The last swap out seemed to work fine except now the web interface shows X-RAID2 (Not-Redundant) which m...
monty77uk
Feb 14, 2013Aspirant
Same problem as OP here .. status says not redundant but space available suggests otherwise.
Disk 1
WDC WD10EAVS-00D7B1 931 GB (32 °C / 89 °F, Write-cache On). Status: OK
Disk 2
ST31500541AS 1397 GB (33 °C / 91 °F, Write-cache On). Status: OK
Disk 3
ST31500541AS 1397 GB (32 °C / 89 °F, Write-cache On). Status: OK
Disk 4
ST2000DL004 HD204UI 1863 GB (30 °C / 86 °F, Write-cache On). Status: OK
..I've had a ticket with Netgear support now for 3 days. They got me to try OS reinstall and now I've left it in debug mode for them to connect and poke about for the past 2 days but still no news.
How do I tell which drive has caused the array issue? If it's a 2Gb I can pull it, use to backup and then start again as I'm only using 1.8Tb of the array. I've already tried pulling a drive and re-sync but no joy, unless I pulled the wrong drive of course.
Volumes
/c
1.8 TB Free Of 3.6 TB
Thanks!
Adam
Disk 1
Disk 2
Disk 3
Disk 4
Volumes
/c
Thanks!
Adam
