Elanthius
Feb 16, 2012Aspirant
Swapped drives now Not-Redundant
My ReadyNAS NV+ v2 was full of 1TB disks and I've been replacing them over time with 3TB disks. The last swap out seemed to work fine except now the web interface shows X-RAID2 (Not-Redundant) which m...
monty77uk
Feb 14, 2013Aspirant
Forgot to add logs:
enclosure.log
mdstat.log
enclosure.log
temp!!1!!status=ok::descr=30.0C/86.0F::expected=0-65C/32-149F
fan!!1!!status=ok::descr=1350RPM::type=SYS
ups!!1!!status=not_present::descr=Not present
volume!!1!!status=warn::descr=Volume C: RAID Level X2, Not redundant. A disk failure will render this volume dead.; 1875 GB (50%) of 3687 GB used
disk!!1!!status=ok::descr=Channel 1: WDC WD10EAVS-00D7B1 931 GB, 30C/86F
disk!!2!!status=ok::descr=Channel 2: ST31500541AS 1397 GB, 32C/89F
disk!!3!!status=ok::descr=Channel 3: ST31500541AS 1397 GB, 31C/87F
disk!!4!!status=ok::descr=Channel 4: ST2000DL004 HD204UI 1863 GB, 27C/80F
model!!0!!mode=home::descr=ReadyNAS NV+ v2::arch=arm1::jbod=1
mdstat.log
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md3 : active raid5 sdb4[0] sdd4[3] sdc4[1]
976749568 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU]
md2 : active raid5 sda3[0] sdc3[3] sdb3[2]
2916122112 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [UUU_]
md1 : active raid1 sdd2[4] sdc2[2] sdb2[1]
524276 blocks super 1.2 [4/3] [UUU_]
md0 : active raid1 sdd1[4] sdc1[3] sdb1[2]
4193268 blocks super 1.2 [4/3] [UUU_]
unused devices: <none>
