TommyDa
Jun 26, 2018Aspirant
Sync to Dropbox
Hi,
I'm using ReadyNAS 312 (6.9.3) and have set "Upload local storage changes only" to backup my NAS (70GB, 30.000 files) to Dropbox.
But not all files are copied. Some folders are empty in cloud...
JohnCM_S
Jun 29, 2018NETGEAR Employee Retired
Hi TommyDa,
Can you try assigning a static DNS on the NAS and see if that will help. You can use 8.8.8.8.
What are the file types saved on those folders?
You can check Dropbox logs by going to the Cloud tab then go to Dropbox Settings. You may refer to the images below on how you can view it:
- TommyDaJun 29, 2018Aspirant
HI,
I already have static DNS (from ISP), but I have added 8.8.8.8 now.
File types: .xls/.xlsx/.doc/.txt/.dwg
50 of 70GB are synced fine. Source have 35.000 files in 27.000 folders.I found a lot of errors in system_log/dropbox.log, but I can not interpret the information.
I attach a small part of log. Can you understand what's the problem?Thanks,
Tommy- JohnCM_SJul 05, 2018NETGEAR Employee Retired
Hi TommyDa,
Can you send to us the complete system logs of the NAS so we can check further what is causing the issue? Please check this link on how you can send it.
- TommyDaJul 05, 2018Aspirant
Hi,
I can't see the link you are referring to.
Tommy
