blobby
Nov 13, 2016Aspirant
System partition filling up and not showing up properly (I think)
Hey Netgear community I hope i'm on the right forum and category for that. I've been troubleshooting some services issues on my Pro6 that seems to be related to the system partition. Samba no...
- Nov 20, 2016
Nevermind, I found another folder that was hidding really well and was the root cause of my problems.
I learned a new linux command on my way :p
mdgm-ntgr
Nov 18, 2016NETGEAR Employee Retired
If you reboot the NAS the root volume might be visible in that list again if you freed up space on it.
But first I would suggest that you make sure that you have an up to date backup.
blobby
Nov 20, 2016Aspirant
Hey,
Thanks for looking at my problem.
I restarted the NAS and the root partition is still not there. However :
df / -h Filesystem Size Used Avail Use% Mounted on - 4.0G 4.0G 0 100% /
I really cleaned the two apps that could log something and its still filling up. Really scratching my head on this one. I just found that :
Blobby-NAS:/var/run/samba# ls -l total 728 -rw-r--r-- 1 root root 40200 2016-11-20 21:04 brlock.tdb -rw-r--r-- 1 root root 552960 2016-11-20 20:34 connections.tdb -rw-r--r-- 1 root root 696 2016-11-20 21:04 gencache_notrans.tdb -rw-r--r-- 1 root root 696 2012-06-01 23:57 gencache.tdb -rw-r--r-- 1 root root 4008472576 2016-11-20 20:34 locking.tdb -rw------- 1 root root 12288 2016-11-20 20:34 messages.tdb -rw------- 1 root root 696 2012-06-01 23:57 mutex.tdb -rw-r--r-- 1 root root 3482 2016-11-20 06:25 namelist.debug -rw-r--r-- 1 root root 5 2016-11-20 20:06 nmbd.pid -rw-r--r-- 1 root root 696 2016-11-20 21:04 notify_onelevel.tdb -rw-r--r-- 1 root root 696 2016-11-20 21:04 notify.tdb -rw-r--r-- 1 root root 12288 2016-11-20 20:06 printer_list.tdb -rw-r--r-- 1 root root 8192 2016-11-20 20:34 serverid.tdb -rw-r--r-- 1 root root 696 2016-11-20 21:04 sessionid.tdb -rw-r--r-- 1 root root 5 2016-11-20 21:04 smbd.pid -rw-r--r-- 1 root root 32768 2015-01-05 21:47 unexpected.tdb drwxr-x--- 2 root winbindd_priv 4096 2008-03-17 22:16 winbindd_privileged
Isn't Samba filling up my drive right here?
- blobbyNov 20, 2016Aspirant
