bedlam1's avatar
bedlam1
Prodigy
May 20, 2016
System Temperature
Am running my PRo 4 under OS 6.5.0 with 4X2TB drives on FlexRaid 5
Just to clarify my post, is a question not a problem as I fail to see how my System" Temperature is reported as being 31C/88F.
This is because the values for each of the drives are 35C/95F, 38C/100F, 37C/98F and 35C/95F and presumably the sum of these divided by 4 is the System Temperature?
If that is the case then 36C/97F would be the expected result ????
The CPU is reported as 39C/102F, I am happy with all these results and OS 6.5.0 which for me is a great improvement over Raidiator 4.2.28, just a bit puzzled.
    No, the pro has a system temperature sensor (not sure exactly where it is placed, but in 4.2.28 linux called it "temperature sensor 2")
  • StephenB's avatar
ProSupport for Business
