JohnT123456
Mar 19, 2019Aspirant
System volume root's usage is 90% RN102
Please can someone help, I am a total novice with these things. I have read some of the post about the same issue, it talks of SSH mumbo jumbo...lol. I have switched SSH on in the admin GUI so shoul...
- Mar 19, 2019
Be careful here, as there are support implications in trying to fix this yourself. Typing the wrong thing can do damage, and require you to do a factory default to recover. So I recommend backing up the NAS first. https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
You first disable the AntiVirus service - which it sounds like you have already done.
The second step is to enable SSH in the NAS web ui in system->settings. If your password is still set to password, you also need to change it to something else.
Now you need a program to connect to the NAS using SSH. Windows 10 has a program built in (called ssh). So do Macs (terminal). For other windows versions you need to install putty from https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html (and you can also use putty on Windows 10 if you like).
Then you use that program to connect to the NAS:
- ssh root@nas-ip-address on Windows 10 (entered on the Windows 10 search bar)
- launch terminal, enter ssh root@nas-ip-address on the mac
- launch putty, make sure ssh is selected as the connection type. Enter the nas-ip-address and click open. Enter root as the username.
Use the real NAS IP address of course. It's important to log in as root. Don't log in as admin. When you see the password prompt, enter the NAS admin password (root and admin use the same password).
If you have trouble launching one of these programs, then you can post back (or just google for more info).
Be careful on the typing of the commands below. Be sure to use the correct slash direction, etc.
After you are logged in, you enter
cd /var/lib/clamav ls -lsh
You should now see a folder listing, with some folders that look like clamav-<very long string>.tmp
If you don't see these tmp folders, then post back and tell us what you do see.
If you do see these tmp folders, then you remove them by entering
rm -r clamav-*.tmp ls -lsh
You should now see a second folder listing, and those tmp folders should be gone.
asimb has posted a screen shot illustrating these commands: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-This-condition-should-not-occur/m-p/1722860#M178464
I'm taking the liberty of re-posting that screen shot here.
I recommend leaving the AntiVirus service off - at least for now.
JohnT123456
Thanks for the quick reply, I think I have got my head round this, one problem....when I try to run SSH command prompt (which I find by searching in the bottom left search box) it only shows up briefly on my screen and disappears...any ideas why this is?
Thanks
JohnT123456
Ok i managed to find a way of getting command prompt ssh enabled using youtube.
next problem is I get to this line
[email protected]'s password:
and it wont accept any key presses from the keyboard..
ahhhhh
any suggestions guys?
Thanks
- JohnT123456Mar 19, 2019Aspirant
Ok Ok stick with me here guys, managed to get it to accept password, not sure how, I think its invisible typing.
anyway the line clamav# ls -lah is whats on the screen grab
and on the text box on this post it say clamav# ls -lsh
so im not sure what to do. lah or lsh
if someone could clarify I would be grateful.
Thanks
went with ls -lsh and it seems to have worked.
tmp files now gone.
does anyone know if this will this be fixed in the next firmware update so I can turn on the antivirus?
many many thanks to the guys who helped.
I will post again if it starts sending me emails again.
- Retired_MemberMar 20, 2019
JohnT123456 wrote: "does anyone know if this will this be fixed in the next firmware update so I can turn on the antivirus?"
On RN10X antivirus service will no longer be available beginning with 6.10 due to the limited resources of this product line.
https://community.netgear.com/t5/ReadyNAS-Beta/Changes-coming-in-RNOS-6-10-0/m-p/1701260#M10461
