JohnT123456
Mar 19, 2019Aspirant
System volume root's usage is 90% RN102
Please can someone help, I am a total novice with these things. I have read some of the post about the same issue, it talks of SSH mumbo jumbo...lol. I have switched SSH on in the admin GUI so shoul...
- Mar 19, 2019
Be careful here, as there are support implications in trying to fix this yourself. Typing the wrong thing can do damage, and require you to do a factory default to recover. So I recommend backing up the NAS first. https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
You first disable the AntiVirus service - which it sounds like you have already done.
The second step is to enable SSH in the NAS web ui in system->settings. If your password is still set to password, you also need to change it to something else.
Now you need a program to connect to the NAS using SSH. Windows 10 has a program built in (called ssh). So do Macs (terminal). For other windows versions you need to install putty from https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html (and you can also use putty on Windows 10 if you like).
Then you use that program to connect to the NAS:
- ssh root@nas-ip-address on Windows 10 (entered on the Windows 10 search bar)
- launch terminal, enter ssh root@nas-ip-address on the mac
- launch putty, make sure ssh is selected as the connection type. Enter the nas-ip-address and click open. Enter root as the username.
Use the real NAS IP address of course. It's important to log in as root. Don't log in as admin. When you see the password prompt, enter the NAS admin password (root and admin use the same password).
If you have trouble launching one of these programs, then you can post back (or just google for more info).
Be careful on the typing of the commands below. Be sure to use the correct slash direction, etc.
After you are logged in, you enter
cd /var/lib/clamav ls -lsh
You should now see a folder listing, with some folders that look like clamav-<very long string>.tmp
If you don't see these tmp folders, then post back and tell us what you do see.
If you do see these tmp folders, then you remove them by entering
rm -r clamav-*.tmp ls -lsh
You should now see a second folder listing, and those tmp folders should be gone.
asimb has posted a screen shot illustrating these commands: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-This-condition-should-not-occur/m-p/1722860#M178464
I'm taking the liberty of re-posting that screen shot here.
I recommend leaving the AntiVirus service off - at least for now.
Jos011157
Mar 21, 2019Aspirant
Thanks, this helped and the files are gone.
Hopefully message stays out.
When / How will we be informed that antivirus can be switched on again?
Regards
Jos
HockeyNomad1
Great Topic started getting the same errors a couple days ago.
RN104 with 4 x 4TB WD Red on 6.9.5.
I found the same issue, clamav folder was filling up. I noticed a couple weeks ago that the AV indicator in the web gui had turned yellow, and a few days ago received the "System volume root's usage is 82%. This Should not occur under normal conditions. Contact Technical Support" message from my NAS RN104, this has been working perfectly since new.
root@ReadyNAS:/var/lib# du -d1 -h 40K ./connman 4.0K ./snmp 4.0K ./dbus 8.0K ./mdadm 4.0K ./nut 12K ./apache2 30M ./mysql 4.0K ./insserv 120K ./ucf 4.0K ./libuuid 2.6G ./clamav 32K ./php5 13M ./dpkg 2.6M ./samba 72M ./apt 4.0K ./update-rc.d 8.0K ./vim 4.0K ./replisync 28K ./pam 4.0K ./misc 8.0K ./sudo 136K ./systemd 4.0K ./urandom 16K ./nfs 4.0K ./initscripts 2.7G . root@ReadyNAS:/var/lib# cd /var/lib/clamav/ root@ReadyNAS:/var/lib/clamav# ls -lhS total 276M -rw-r--r-- 1 root root 162M Mar 6 04:14 daily.cld -rw-r--r-- 1 root root 113M Oct 9 2017 main.cvd -rw-r--r-- 1 root root 990K Jan 2 17:21 bytecode.cld drwxr-xr-x 3 root root 4.0K Mar 12 04:18 clamav-1052674f670d6fa214f5d8723b001e10.tmp drwxr-xr-x 3 root root 4.0K Mar 17 13:22 clamav-12c4946d6d4083884efc403bb8b31b15.tmp drwxr-xr-x 3 root root 4.0K Mar 19 13:23 clamav-30c842f8c25ec16062fb0b6ab310b83d.tmp drwxr-xr-x 3 root root 4.0K Mar 11 04:17 clamav-381bb4ee2680af85d7b6a0312043aff8.tmp drwxr-xr-x 3 root root 4.0K Mar 7 04:14 clamav-3b65e5839c926ce2d5b94f6533d2a416.tmp drwxr-xr-x 3 root root 4.0K Mar 9 04:15 clamav-4bf40655f003ddd7324deceb0e68f929.tmp drwxr-xr-x 3 root root 4.0K Mar 12 13:26 clamav-60161bf85190b4b62e96e7c28aa0d5fd.tmp drwxr-xr-x 3 root root 4.0K Mar 8 04:15 clamav-622892ca4baa94df9e6b4c5e6635ecea.tmp drwxr-xr-x 3 root root 4.0K Mar 13 13:27 clamav-6b4e0c8587bdc08fee089fb74b67c604.tmp drwxr-xr-x 3 root root 4.0K Mar 18 13:22 clamav-8f9e7433684605db15a69dd76769f85b.tmp drwxr-xr-x 3 root root 4.0K Mar 15 13:21 clamav-9dc4d920abae9ed1649e0370c8e823cd.tmp drwxr-xr-x 3 root root 4.0K Mar 14 13:21 clamav-a5c4514b24634f7e4ea9fbbfd20cda1e.tmp drwxr-xr-x 3 root root 4.0K Mar 10 04:16 clamav-df569d3b49c09f275d74b7fd9e44b9a8.tmp drwxr-xr-x 3 root root 4.0K Mar 16 13:22 clamav-f8970b2254f8259e1a5d0e67140b8466.tmp -rw------- 1 root root 1.4K Mar 19 13:23 mirrors.dat -rw-r--r-- 1 root root 48 Mar 6 04:16 antivir.ini root@ReadyNAS:/var/lib/clamav# du -d1 -h 166M ./clamav-df569d3b49c09f275d74b7fd9e44b9a8.tmp 166M ./clamav-12c4946d6d4083884efc403bb8b31b15.tmp 166M ./clamav-4bf40655f003ddd7324deceb0e68f929.tmp 166M ./clamav-3b65e5839c926ce2d5b94f6533d2a416.tmp 166M ./clamav-f8970b2254f8259e1a5d0e67140b8466.tmp 166M ./clamav-622892ca4baa94df9e6b4c5e6635ecea.tmp 166M ./clamav-9dc4d920abae9ed1649e0370c8e823cd.tmp 166M ./clamav-381bb4ee2680af85d7b6a0312043aff8.tmp 166M ./clamav-30c842f8c25ec16062fb0b6ab310b83d.tmp 166M ./clamav-6b4e0c8587bdc08fee089fb74b67c604.tmp 166M ./clamav-1052674f670d6fa214f5d8723b001e10.tmp 166M ./clamav-60161bf85190b4b62e96e7c28aa0d5fd.tmp 166M ./clamav-8f9e7433684605db15a69dd76769f85b.tmp 166M ./clamav-a5c4514b24634f7e4ea9fbbfd20cda1e.tmp 2.6G . root@ReadyNAS:/var/lib/clamav# rm -r clamav-*.tmp root@ReadyNAS:/var/lib/clamav# ls -lhS total 276M -rw-r--r-- 1 root root 162M Mar 6 04:14 daily.cld -rw-r--r-- 1 root root 113M Oct 9 2017 main.cvd -rw-r--r-- 1 root root 990K Jan 2 17:21 bytecode.cld -rw------- 1 root root 1.4K Mar 19 13:23 mirrors.dat -rw-r--r-- 1 root root 48 Mar 6 04:16 antivir.ini root@ReadyNAS:/var/lib/clamav# cd / root@ReadyNAS:/# du -d1 -h 4.0K ./dev 365M ./usr 16M ./opt 11M ./etc 620M ./var 21M ./apps 30M ./frontview 4.0K ./boot 0 ./sys 28M ./run 32K ./media 28M ./lib 4.0K ./srv 52K ./root 0 ./proc 16K ./lost+found 10M ./sbin 6.0M ./bin 27M ./home 28K ./tmp 1.6T ./data 4.0K ./selinux 1.6T . root@ReadyNAS:/#
So Looks like we need an update sharpish I have now disabled the AV although it still seems to be trying to update as the filesystem grew again overnight. so i will now remove the .tmp files as the 14 .tmp files are eating 2.3G on their own.
but thanks to this thread I'm working correctly although with clamav disabled. and now i know what to do to if the directory grows again.
