JohnT123456
Mar 19, 2019Aspirant
System volume root's usage is 90% RN102
Please can someone help, I am a total novice with these things. I have read some of the post about the same issue, it talks of SSH mumbo jumbo...lol. I have switched SSH on in the admin GUI so shoul...
- Mar 19, 2019
Be careful here, as there are support implications in trying to fix this yourself. Typing the wrong thing can do damage, and require you to do a factory default to recover. So I recommend backing up the NAS first. https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides
You first disable the AntiVirus service - which it sounds like you have already done.
The second step is to enable SSH in the NAS web ui in system->settings. If your password is still set to password, you also need to change it to something else.
Now you need a program to connect to the NAS using SSH. Windows 10 has a program built in (called ssh). So do Macs (terminal). For other windows versions you need to install putty from https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html (and you can also use putty on Windows 10 if you like).
Then you use that program to connect to the NAS:
- ssh root@nas-ip-address on Windows 10 (entered on the Windows 10 search bar)
- launch terminal, enter ssh root@nas-ip-address on the mac
- launch putty, make sure ssh is selected as the connection type. Enter the nas-ip-address and click open. Enter root as the username.
Use the real NAS IP address of course. It's important to log in as root. Don't log in as admin. When you see the password prompt, enter the NAS admin password (root and admin use the same password).
If you have trouble launching one of these programs, then you can post back (or just google for more info).
Be careful on the typing of the commands below. Be sure to use the correct slash direction, etc.
After you are logged in, you enter
cd /var/lib/clamav ls -lsh
You should now see a folder listing, with some folders that look like clamav-<very long string>.tmp
If you don't see these tmp folders, then post back and tell us what you do see.
If you do see these tmp folders, then you remove them by entering
rm -r clamav-*.tmp ls -lsh
You should now see a second folder listing, and those tmp folders should be gone.
asimb has posted a screen shot illustrating these commands: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/System-volume-root-s-usage-is-xx-This-condition-should-not-occur/m-p/1722860#M178464
I'm taking the liberty of re-posting that screen shot here.
I recommend leaving the AntiVirus service off - at least for now.
Bernard46
Dec 31, 2023Aspirant
I've suddenly started getting similar messages to others mentioned in this series of posts. Unfortunately I'm completely ignorant when it comes to Unix commands so I really don't know what to do - I have followed the earlier instructions but now I'm stuck. Antivirus has been switched off on my NAS 102 (running 6.10.2) for some time, possibly over a year. The only app on the device is Resilio Sync and that has never been used.
The log for today shows the following messages:-
| 31 Dec 2023 12:30:04 | System: Service protocol SSH is enabled. | |
| 31 Dec 2023 08:00:14 | Volume: System volume root's usage is 84%. This condition should not occur under normal conditions. Contact technical support. | |
| 31 Dec 2023 00:35:47 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN Videos. | |
| 31 Dec 2023 00:35:36 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN readydrop. | |
| 31 Dec 2023 00:35:34 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN Pictures. | |
| 31 Dec 2023 00:35:31 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN Music. | |
| 31 Dec 2023 00:35:29 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN JillsEdge. | |
| 31 Dec 2023 00:35:22 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN HOME-XPS-Documents. | |
| 31 Dec 2023 00:35:18 | Snapshot: Snapshot prune worker successfully deleted snapshot 2023_12_03__00_00_00 from share or LUN Documents. | |
| 31 Dec 2023 00:00:38 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN Videos. | |
| 31 Dec 2023 00:00:37 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN readydrop. | |
| 31 Dec 2023 00:00:35 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN Pictures. | |
| 31 Dec 2023 00:00:33 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN Music. | |
| 31 Dec 2023 00:00:31 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN JillsEdge. | |
| 31 Dec 2023 00:00:27 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN HOME-XPS-Documents. | |
| 31 Dec 2023 00:00:26 | Snapshot: Snapshot c_1703980822 was successfully created for share or LUN Documents. |
I've enabled SSH and run the SSH command and entered a few of the commands mentioned in earlier posts - the results are above. The log messages says the ROOT directory is 84% full (and climbing by 1% every 2 or 3 days) - the df command seems to say a directory (md0 ?) is 89% full, but I'm not sure these are talking about the same thing - probably not.
Please can someone shed some light on what is happening with this system and what I should do to resolve what looks like a serious problem looming?
Bernard
