miked4u
Nov 08, 2016Aspirant
Tech support
After installing a recent OS 6 upgrade (from 6.5.1 to 6.6.0) to my Readynas312, the backup feature fails to operate. I have reached out to the community forum for help but that has not been fruitful...
- Nov 10, 2016
I much appreciate your efforts and attention to resolving my issue. Since adding an actual account name, my backups seem to be working again which I am very pleased about. I do question, however, that the root of the problem lies with changes in Windows because: 1) This issue first became apparent to me a couple of months ago when I went from OS 6.5.1 to 6.5.2. 2) When I reverted to 6.5.1 again, I was able to do backups without adding any login information. 3) If the problem was on the Windows side, it seems that I would have had to add login information irrespective of the version of Ready NAS OS I used (6.5.1 or 6. 6.5.2 or 6.6.0). To me it seems that the problem is in whatever changes (or ommissions) were made in coding in version 6.5.2 which have been carried forward. Admittedly, I have no great expertise in this area, so I may be very wrong; I am just applying some logical reasoning.
One other thing comes to mind. You may want to make this information more widely known because the setup information and guides must now be updated. As I remember, the setup information suggests that if you turn off the need for a logon password in Windows, you do not have to add the login information now beiing requested. I am certain that many people are being frustrated by this change.
In any case, the matter is now moot and I am a happy person. Thank you again.
Skywalker
Nov 09, 2016NETGEAR Expert
The root cause of this is a change in Windows that requires guest logins to supply a username, but the username must not exist on the Windows system. So, basically we need to supply a bogus username. The SMB mount utility doesn't do that, and thus recent Windows versions reject the guest login. You can work around the problem by having the backup job log in to the share with an actual account. Alternatively, if you'd like to continue using a guest login, you should be able to fix it by installing one of these packages: ARM or x86_64. Install through Apps -> Upload.
miked4u
Nov 10, 2016Aspirant
- SkywalkerNov 10, 2016NETGEAR Expert
Yes, absolutely it's a combination of factors. Guest authentication against Windows 7 works from both 6.5.1 and 6.6.0. So certainly there is a change in behavior with recent Windows versions in play here. Also, there was a bug fix added to the Linux kernel (here) to comply more fully with Microsoft's SMB spec (here) when doing guest authentication. This change dropped between 6.5.1 and 6.5.2, and broke guest authentication against Windows 10. So either Windows 10 is violating the MS SMB spec, or there was a misunderstanding of the spec by the Linux kernel developers. It's not obvious to me at this point which is the case, but we're still pursuing it.
6.6.1 will work around the issue by adding an automatic retry of guest authentication attempts with a bogus username added.
- StephenBNov 10, 2016Guru - Experienced User
This is very helpful, and explains why so many people have needed to add credentials via the windows credential manager in recent months.
