JessKaufman
Aug 09, 2011Aspirant
Technical challenge for RNDU4000 Ultra 4 (#16372263)
Ok, here's what I am faced with. I had a perfectly fine ReadyNAS Ultra 4 with 4 x 3 Tb drives running 4.17 with about 3-4 Tb of data on it. I moved it to a new lan with different IP arrangement an...
JessKaufman
Aug 19, 2011Aspirant
1. I am not mad
2. I did not choose the menu item. There was only ONE . factory defaults
3. I did not refer to a manual. I merely used the button on powerup to get the choice to reset factory defaults.
4. After i selected defaults, there is no message that YOUR DATA WILL BE WIPED. That is what I am talking about. HUGE oversight. HUGE.
