ziemowit
Oct 01, 2021Aspirant
Technical support mode password for Netgear NAS
Hi, everybody! I have recently discovered that my two NAS units (NV+ v1 and Ultra 6) have developed a strange problem, similar on both units and yet I know they are different OS and different CPU...
ziemowit
Replying to myself: have located the username/password for NV+ v1 on this forum.
What about the others?
Sandshark
Oct 01, 2021Sensei
SSH login user name is root, using the admin password. SSH must be enabled, of course. That's a simple config option in OS6 but requires an add-on for the NV+ V1.
- ziemowitOct 01, 2021Aspirant
Thanks for the reply, but sorry - that is not a reply to my question.
I am asking for the username and password for the Technical Support mode (via Telnet), I am not asking about SSH logins.
- StephenBOct 01, 2021Guru - Experienced User
It's root/infr8ntdebug for all models of ReadyNAS.
- ziemowitOct 12, 2021Aspirant
Thank you! Problem solved from my side, I logged in and did some cleanup. Cleanup helped.
