raj1112
Sep 28, 2026Follower
Technical Support Required: ReadyNAS RN31400 - Main Hard Disc Not Detected / Showing in Software
Dear Netgear Support Team,
I am writing to request technical assistance with my ReadyNAS RN31400 unit.
The main hard disk is not attaching or showing up in the ReadyNAS management software. It appears to be a hardware-related issue, as the system fails to detect the drive entirely.
Here are the details of the device:
Model: ReadyNAS RN31400
Issue: Main hard drive not visible/detected in the software interface.
Could you please guide me through the troubleshooting steps to diagnose whether this is a faulty drive, a slot/backplane issue, or a firmware glitch? Please let me know the process for hardware inspection or replacement if required.
Looking forward to your prompt response.
Two obvious possibilites are a failed SATA slot in the chassis or a failed drive.
I think a failed drive is more likely. The easiest next step is to power down the NAS and connect the drive to a Windows PC and test it with vendor tools (currently Seatools for Seagate and KitFox for WD). You can connect it using a USB/SATA adapter or dock. Make sure the NAS stays powered down until the test is completed.
- SandsharkSensei
Are all bays of the NAS filled?
At this point, is your volume active and accessible, but reporting degraded? If so, and the drive is what's bad, then you simply need to replace it with another that's at least as large. That's best done with power on.
But before you do that, you should make sure your backup is up to date. Re-syncing a new drive is harder on the remaining drives than normal use. If you have a drive ready to fail ( a real possibility if all drives are the same age), the re-sync may drive it to failure. And if it does, your volume is lost and data is unrecoverable.
If your volume is not accessible, then it may have been damaged when the drive failed. You need to figure out if it's the drive or NAS hardware that's the issue before tackling volume recovery.
If the drive passes vendor tests, come back and we can give you a couple extra steps it check if it's the NAS hardware. If it is, repair is unavailable. Replacement is the only option. And then you have a hard choice to make: buy a used replacement ReadyNAS or buy somehting else that's still supported by the manufacturer. If you decide on a used replacement, any 4-bay or larger ReadyNAS running OS6 will work with your volume, but the Intel-based models (3xx and above or some legacy units converted to OS6) are recommended.
