masa2
Aug 14, 2012Tutor
TFTP Boot Recovery
When performing TFTP Boot recovery. When I uploaded the files with tftp server, the readynas turned itself off. Then I restart it by doing 5 second reset. It starts creating volume but then after a wh...
mdgm-ntgr
Aug 15, 2012NETGEAR Employee Retired
Yes that's the guide for USB Boot Recovery for the v1. Link to the USB image is in the FAQ.
I guess you should try a USB Boot Recovery followed by an OS Re-install or Factory Default.
If it still doesn't work contact support. If still within 3 years of purchase an RMA might be needed.
