Cyborg-2019
Feb 20, 2019Aspirant
The Admin page of ReadyNAS RN2120 device dosen't work properly after firmware 6.9.4 upgrade.
Hello All,
We have ReadyNAS RN2120 device which I used to access via the admin page (https://server IP) to do some admin tasks.
The firmware was updated to 6.9.4 on it and probably after that the admi...
Mar 12, 2019Guru - Experienced User
Do you have ssh enabled on the NAS? If so, can you connect with it?
If you have reasonable linux skills, you could check the OS partition fullness in tech support mode. You'd log into the NAS with telnet, and then manually mount the OS partition.
Cyborg-2019
Mar 13, 2019Aspirant
Hi StephenB,
No ssh is not enabled there. I checked it and couldn't login via ssh.
Do you know if it is possible to rollback the 6.9.4 firmware upgrade to the previous version?
- StephenBMar 13, 2019Guru - Experienced User
That is possible if you have access to the web UI, but you shouldn't attempt it. If the OS partition is very full, it would fail - and it might damage the configuration files.
How much experience to you have with the linux CLI? If you don't already know it (or need to limit the risk of data loss), you are better off using paid support via my.netgear.com.
Either way, you should definitely back up all the data - it is at risk.
