Marova
Jul 24, 2021Aspirant
The device is not set up to accept connections from port "The File and printer sharing (SMB)"
Hi! About two weeks ago I had a blackout at my apartment and when I got home and turned everything on again I was met by this message when I tried to connect to my NAS: At first I tried to go...
- Aug 03, 2021
Marova wrote:
So how do I fix my NAS now that the data is off-loaded?
You can do a factory default using the front panel, which will set up the NAS from scratch. The process is described on pages 15-16 here: https://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf It might take about 30 minutes to come back on-line after the process begins.
After you regain connectivity, set up the NAS again and restore the data from your backup.
Jul 24, 2021Guru - Experienced User
Try installing RAIDar on the PC, and tell us what status it gives for the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads
Do you recall what firmware you were running on the NAS? Do you see ReadyNAS Duo on the front panel, or do you see ReadyNAS Duo v2 ?
- MarovaJul 25, 2021Aspirant
Status: Healthy
Firmware: 4.1.16
It only says ReadyNAS Duo on the front panel
- StephenBJul 25, 2021Guru - Experienced User
Marova wrote:
Status: Healthy
Firmware: 4.1.16
Ok. Then you have the original Duo (v1), and not the v2. The firmware is the final release.
Do you have a backup of the files, or do you need to offload them for safety?
No back-up unfortunatly, so I need to offload them if I can't find a way to access the NAS
