blinke
Sep 20, 2017Aspirant
The seems to be dead, has worked for many years what can I do?
This NAS has served me and my church for many years, a few weeks ago I did an update to the firmware and all seemed to be OK, last week I went to access it and couldn't any longer see it on the netwo...
Sep 21, 2017Guru - Experienced User
It sounds like the power supply failed.
You have a couple of options
- it is possible to replace the PSU, especially if you are comfortable changing the pin-out on a stock power supply. Let us know if you want to pursue that option.
- You can mount the disks in an x86 linux system to offload the data. There is a guide here: http://home.bott.ca/webserver/?p=306
- You can get a newer NAS, and offload the data from your current disks with help from Netgear support: https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
Netgear's current equivalent to the NV+ is the RN214. It is much faster, supports much larger disks, and has a lot of features that aren't in your NV+. US street price is about $400 at the moment.
