as_
Nov 11, 2021Aspirant
The volume data encountered an error and was made read-only. It is recommended to backup your data.
Was copying data onto my NAS from external hard drives for backup purposes (just had an external drive fail.. so.. I'm a bit paranoid on that right now..). All of a sudden, I couldn't transfer files ...
Nov 11, 2021Guru - Experienced User
as_ wrote:
The logs tell a different story:
Nov 08, 2021 03:02:30 PM
Volume: The volume data encountered an error and was made read-only. It is recommended to backup your data.Nov 08, 2021 04:37:10 AM
Volume: Less than 5% of volume data's capacity is free. data's performance is degraded and you risk running out of usable space. To improve performance and stability, you must add capacity or make free space.Nov 07, 2021 11:57:49 PM
So.. now what?
Have you backed up your data?
- as_Nov 11, 2021Aspirant
No, I have not. Most of the data on the NAS is data I have stored on other local drives.. but not all of it.
- StephenBNov 11, 2021Guru - Experienced User
Data loss is very possible (and reformatting/starting over is in fact the simplest way to proceed). So it'd be good to back up everything you care about first.
I'll start there with the backup.. but that said, we're talking about 20TB of data (4x8TB drives). Formatting the drive and starting over is absolutely the last thing I want to do.
