swehjo
Jun 29, 2013Guide
Three disk failurs within 15 months on same channel
I have now had three disk failures, february -12, october -12 and now june -13, all on channel three. Seagate disks all three. Normally this channel has also been running slightly hotter than the ...
swehjo
Jun 30, 2013Guide
Hmmm, Netgear seams to say up to 60C is normal. The fan has been recalibrated and I did it right now. No difference, same temp. I don't know if its speed says something, 2143RPM!?
But again, it's only channel three where the disks fails and its on that channel the temp is a couple of degrees hotter which I think i strange. Also with a new replacement disk inserted.
