matgr
Jul 11, 2011Aspirant
Time Machine & Lion
Not happy together as far as I can tell
mdgm-ntgr
Jul 21, 2011NETGEAR Employee Retired
hawkeye wrote: Same here, just upgraded to the beta (RAIDiator 4.1.8-T5 [1.00a043] ). I can mount afp volumes read/write, but timemachine doesn't work. The log in the console was:
21/07/2011 22:41:47.155 com.apple.backupd: Destination /Volumes/backup does not support TM Lock Stealing
THanks for the quick turnaround on the beta, am sure you'll get it all working pretty soon!
You're getting that error because you're not using the supported way of doing TM backups. You'll either need to edit the AFP config for that share or change to using the supported method. See http://www.readynas.com/forum/viewtopic.php?f=71&t=55166
