matgr's avatar
matgr
Time Machine & Lion
Not happy together as far as I can tell
  • Firmware .18 fixed it up on my Pro Business; all's well. Thanks for the quick action, Netgear!
  • i try to update but i recived always a Problem report after the validation.
    "Ungültige Prüfsumme in der Update-Datei. Das Update wird abgebrochen."
    can be the german be a problem? is the beta only for english?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Mitschka 4.1.8-T5 should install fine on your NV+. Is that what you were trying to install?
  • yes i do this version.
    the update is upload the file an then i had the possibility to start the update. second later a popup start up ant tell me somoesing from a bad proof summary (sorry for the english)
ProSupport for Business
