matgr
Jul 11, 2011Aspirant
Time Machine & Lion
Not happy together as far as I can tell
- forddonaldAspirantFirmware .18 fixed it up on my Pro Business; all's well. Thanks for the quick action, Netgear!
- mitschkaAspiranti try to update but i recived always a Problem report after the validation.
"Ungültige Prüfsumme in der Update-Datei. Das Update wird abgebrochen."
can be the german be a problem? is the beta only for english? - mdgm-ntgrNETGEAR Employee RetiredMitschka 4.1.8-T5 should install fine on your NV+. Is that what you were trying to install?
- mitschkaAspirantyes i do this version.
the update is upload the file an then i had the possibility to start the update. second later a popup start up ant tell me somoesing from a bad proof summary (sorry for the english) - mdgm-ntgrNETGEAR Employee RetiredHave you tried 4.1.8-T9? See http://www.readynas.com/forum/viewtopic.php?f=17&t=55155
