GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
mdgm-ntgr
Jul 20, 2009NETGEAR Employee Retired
imagenes_vivas wrote:
chirpa wrote: RAIDiator 4.2.6 road map is to support 2TB+ volumes for iSCSI/TimeMachine/etc, I don't have a timeframe for that release yet.
Chirpa, last April do you really mean 4.2.6 or the now just released 4.1.6?
4.2.6 is referring to the next X86 Firmware for e.g. Pro, NVX. 4.1.6 is the current (just released) Sparc firmware for e.g. NV+, Duo etc. I imagine they should be working on a fix for both X86 and Sparc.
