GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
centauratlas
Aug 10, 2009Tutor
Thank you, I will keep an eye on it!
mdgm wrote:
centauratlas wrote: Any news on this? I too had purchased a ReadyNAS Pro and didn't see a mention of this limit. It has been more than 4 months and thought I'd ask what the status is and if there is a timeframe now. (The DroboPro doesn't have this problem and I am considering the options available now or in the not too distant future since it has been a while and the ReadyNAS is just depreciating :-) )
Any beta's available?
chirpa wrote: RAIDiator 4.2.6 road map is to support 2TB+ volumes for iSCSI/TimeMachine/etc, I don't have a timeframe for that release yet.
No beta's available yet. For the Pro and other X86 keep an eye on http://www.readynas.com/forum/viewforum.php?f=51
For NV+ and other Sparc see http://www.readynas.com/forum/viewforum.php?f=17
If 2TB+ support is added it will be in the release notes for the beta.
Bear in mind that although NetGear almost certainly tests their betas before making them public, in particular early betas can have issues so it's even more advisable than with an ordinary version of RAIDiator to backup any crucial data regularly if you choose to use a beta once it comes out.
