GreenmanX
Apr 06, 2009Aspirant
Time Machine 2tb limit?
Hi! I tested the ReadyNAS Pro equipped with 6tb. We (ad agency) are planning to use it with TimeMachine to backup our desktop macs. I wanted to use the maximum capacity, which is 4607GB, for TM, b...
mdgm-ntgr
Apr 05, 2010NETGEAR Employee Retired
RAIDiator x86 4.2.10 Beta makes some changes:
yoh-dah wrote:
Enhancements:
1. [T40] Default file system for all x86 devices is now Ext4. If you factory default the ReadyNAS with 4.2.10, you will get the Ext4 with support for files as large as 16TB on 64-bit ReadyNAS systems (Pro, 3100, 3200, 4200). If you upgrade from Ext3, you’ll still be limited to 2TB. We are looking at coming out with an add-on that allows you to convert your Ext3 file system to Ext4.
4. [T40] Time Machine limit is now 4TB with Ext4 on 64-bit systems (2TB otherwise).
